Rca jack upgrade for c-4
Best design I've seen for an RCA jack has a couple spring loaded blades that grip the full length of the center pin when you insert the cable. Lots more contact, and self cleaning. Hard to beat the combo.
I would like to see them and where did you find them.:scratch2:
The RCA's are finished.:banana: Just have to install the ground post and put it back together. It makes the back of the C-4 shine. :thmbsp:
Well here it is all finished. I installed the double ground post. When i get my order from Vampire Wire i will install the gold ones.:smoke:
Looks great! more room for these on the C-4 compared to some other Yamaha pre's.
Thanks. It worked out great and it sure looks good. It was time comsuming. More work than I thought. I recapped it to while I had it apart. The distance between the new RCA's ended up being the same distance as the old. So that was a good thing. I will hook it up to my system today and see how it sounds.:music:
Very nice mod, better to know how good your input connections are now rather than depending on 30+ year old solder joints and surfaces.
Up Date. Been running the C-4 for two days now every thing is working great. I checked all the RCA's and everyone is working fine. I have two M-4's and two TT's connected to it and it is sounding Awesome. I can't say it's because of the new RCA's because I recapped it at the same time. But I can say I am thrilled with the results. The double ground posts are differently a plus.:banana:
It went great. This is the second one I recapped. This one I used Nichicon FG and Muse caps. Some of the ones I couldn't get I ended up using the New KA's. Sounds nice recapped and with new RCA's.
