Starting another RCA RS-177A thread--I know there are several, and I have read through many, but this is my first tube project and I want to consolidate all of my noobish questions in one place.
For reference, to start, photos of top and bottom and a cropped schematic of the power amp, without the preamp and tuner.
I know this unit is a bit scant on gain--but my intent is to clean up the extraneous switches and jacks, recap, and add fuse, power switch, binding posts and rca jacks keeping the schematic more or less stock before deciding if I want to add an additional gain stage or modify the existing gain stage.
-I have new .27uf Panasonics to replace the wax and paper caps, as well as the 2x 100pf (MMF) capacitors
-I have new individual electrolytics for the multi-section can caps.
A couple of questions to start:
What wattage are the resistors on the schematic, if no wattage is listed?
And/or what is a suitable replacement?
For maximum flexibility in the future, should I plan to use the 4ohm or 8ohm feeds?
What rating fuse would be sufficient? I believe someone in another thread suggested 1A slow-blow?
