What does "1/2 B+" mean? Also, what is the best way to insulate the caps?just watch the doubler caps, the negative side of the "upper" cap will be at 1/2 B+. It needs to be insulated from the chassis.
That’s ok, any volume would be ok. Right now I’m just trying to see if my problem is with the amp or with the tuner, so I was hoping to at least hear if any sound is moving through the amp. Currently the tuner powers on but I have no sound, not even the radio.The amp only has the 6GF7 AF amp so it needs another gain stage which is located on the tuner. You won't get much volume out of the amp by itself without the tuner/preamp or extra gain stage.
