So as the title says I found this old RCA amp off the auction site and it is almost the same as the RCA SP-20 amps that I want to recreate from new parts using the original drawings. So I thought I would do a little practice by working on this and getting a better knowledge and some practice and then I can compare the amps once I finish.
This will be a recap of the RCA RS147 and the steps I do to get it up and running.
First is a bit of clean up as this thing was crusty.
Next I am working on the replacing the can caps. I found all of these on amplified parts, and I am starting with C64A,B 100/100-50 volt. The replacement is quite a bit larger but it is a 100/100-500 volt can.
