RCM - how much cleaning fluid?
MX5Seeker
Prog-aholic
For those of you with RCMs, how much cleaning fluid do you use? I just got an Okki Nokki (I'll review it later). I diluted their cleaning fluid in 1 quart of distilled H2O). I then used 6ml per side. That was too much and actually ran onto the bottom side of the record. I'm thinking 4 ml would be plenty, but I want it to be "wet" enough to do the job.
So, suggestions?
On my Nitty Gritty MiniProII I use enough fluid to cover the LP completely. I do not measure, just pump until surface is covered.
I don't measure either. Just enough fluid so the record is covered completely after a rotation or two.
I use 20-30 drops of cleaning brew spread out over the record, and dip my MoFi brush into my container of distilled water and wet the record with the brush. Let soak a couple minutes and then vac for 2 rotations.
I use 2ml per side. Usually I just know by manual application ... look/feel that I have 2ml on the record side .... but when I do measure (syringe) ... it's 2ml.
That's what I'm using, a 10ml syringe. I may try using 2ml and move up if that's not enough.
Enough to cover the record from lead in to run out groves and not so much as to run off the edge of the record. The key to a good cleaning is "soak time". Followed by the same amount of distilled water and a thorough vacuuming.
So, do you use 2 separate brushes and vacuum wands? One pair for solution and one for the "rinse"?
I use a hand pump spray bottle that is marketed by Pampered Chef to spray olive oil, I get a spray similar to pressure of a can of cooking spray and I can thinly and evenly coat the surface before I brush it.
It works great and gives the spray a nice bit of pressure. Its easy to handle and is about the size of a D cell flashlight.....a few pumps and it sprays a few albums.
