JonL
Lunatic Member
I have a question for those of you who use and are satisfied with a vacuum record cleaning machine. How strong is the vacuum, and how much bypass air goes through whatever kind of strips seal against the record? Is the vacuum so strong that the record is pulled tight against the seals with very little air flowing through?
I have a Record Doctor / Nitty Gritty RCM that I've never found truly satisfactory in its cleaning performance. I don't feel that it cleans my records well enough to justify the claims many make for their vacuum RCMs. Even after as many as ten revolutions over the vacuum slot, my records still have a bit of visible moisture on them and need to dry in a dish rack for a few minutes. I wonder if my dissatisfaction is due to the RCM not effectively vacuuming away all the fluid and contamination, leaving some dirt behind to dry up in the grooves.
The vacuum on the unit is so strong that it sucks the record down tight against the "velvet" sealing strips, allowing very little air to come through. It seems to me that the vacuum has to create a high velocity air stream through the grooves in order to effectively suck away the fluid and debris. With the record pulled so tightly against the lips, there is very little air flow, thus my damp records and perhaps my less than optimum cleaning.
I haven't seen any difference with brand new, carefully applied OEM lips. I'm thinking of experimenting with homemade lips with taller, somewhat stiffer fibers, or a material with less fiber density (perhaps from a paint pad). I'm also thinking of putting a hole in machine to spoil some of the vacuum. (Or maybe I can run it on a variac first to test the theory... actually, slowing down the vacuum motor with a variac or bucking transformer might quiet the damn thing down a bit too...)
Anybody have any thoughts or experience to share on this?
Thanks!
Thanks!
