RD 1140 sherwood reciver
zari
I have problem when turn on the reciver tuner mode. There no sound after couple's of min. I start listen radio but low level sound. The volume. Button max what is the solution for this probem?the Aux for exm is OK sound great. Only tuner problem
Ari
I see you screwed up and posted this like five times. The mods will probably remove the extra ones soon. Let's hope all the replies come to this one.
Anyway, I don't see the print on hifiengine so it might be hard to help. If everything else works, sometimes it is a 12 volt regulator feeding the tuner. Like a 7812, sometimes a 7809. They go bad, and also the connections on the board because they develop heat. Solder does not expand and contract well.
