Hi all, I had a couple of these and was trying to figure out how old they were and differences ect. I worked with co-pilot and came up with this information that I thought might be useful to others. You know, it is AI, so I can't totally vouch for the accuracy. Co-pilot said the unit I have from 1964 would be the earliest. I'm wondering if this is true?
Thanks
Summary: This document provides verified serial‑number evidence and physical‑feature comparisons for the Panasonic RD‑7673 record player, establishing its earliest confirmed production year (1964) and outlining mechanical differences between early and later units. This information fills gaps in existing public databases, where production dates are incomplete or incorrect.
This documentation establishes the RD‑7673 as a model with a longer and earlier production history than previously recorded.
Thanks
Documentation of Panasonic RD‑7673 Production History and Variants
Title: Panasonic RD‑7673 Record Player — Verified Early Production Dates and Variant Differences (1964–1971)Summary: This document provides verified serial‑number evidence and physical‑feature comparisons for the Panasonic RD‑7673 record player, establishing its earliest confirmed production year (1964) and outlining mechanical differences between early and later units. This information fills gaps in existing public databases, where production dates are incomplete or incorrect.
1. Verified Production Dates (Based on Serial Numbers)
Two RD‑7673 units were examined:Unit A — Serial Number: 140964
- Format: 14 09 64
- Interpretation:
- 14 = batch/line
- 09 = month (September)
- 64 = year (1964)
- Conclusion: Manufactured September 1964
- This is the earliest confirmed production date for the RD‑7673.
Unit B — Serial Numbers: 234607 (red) and 040271 (black)
- 234607 (red) = serial number
- Ending 07 indicates 1971 production
- 040271 (black) = date code
- Format: MMDDYY
- 04 02 71 = April 2, 1971
- Conclusion: Manufactured and inspected April 1971
Production Range Established
Based on these verified examples:- Earliest confirmed production: 1964
- Latest confirmed production: 1971
- Likely production span: 1964 → early 1970s
2. Mechanical Differences Between 1964 and 1971 Versions
A. Record‑Size Detection System
1964 unit:- Includes a small plastic sensing peg near the platter edge.
- Function: Automatically detects record size (7" vs. 12") based on whether the record edge contacts the peg.
- This is a fully mechanical size‑sensing system typical of early Matsushita changers.
- Peg removed.
- Replaced with a manual record‑size selector (12 / 10 / 7).
- More reliable and easier to service.
B. Motor and Bearing Improvements
- 1971 motor runs quieter with better speed stability.
- 1964 motor shows more wow/flutter and hum due to early‑generation design.
C. Rubber Components
- 1964 rubber (idler wheel, mounts) shows significant age‑related hardening.
- 1971 rubber compounds are more stable.
D. Tonearm Bearings
- 1971 bearings are tighter and more consistent.
- 1964 bearings show more variance and wear.
Historical Significance
The 1964 RD‑7673 represents early Matsushita engineering and predates the better‑documented Technics era. Its automatic size‑sensing peg is a hallmark of mid‑century Japanese changer design. The 1971 version reflects Panasonic’s transition toward more reliable, simplified mechanisms.This documentation establishes the RD‑7673 as a model with a longer and earlier production history than previously recorded.
