Re mac 1900 gain
ducati2
AK Subscriber
My Mac 1900 runs great and sounds great after a full rebuild and adjustment, shower I have one issue. It is most difficult to run at very low volume, especially in fm. Wondering if I missed an adjustment or something. As we know, the volume pots are the weak spot on these units, but I installed a new one from Mac and still have same issue. Some gain pot or something ? Any thoughts appreciated!
From what I've seen when the pot is fully CCW down near where you turn it on that's where the resistance through the pot is just "getting started," the values are lower, and the differences between L/R output is most obvious. In my experience, if you can get the volume turned up a bit more the tracking is better which makes differences less noticeable. You can do that by reducing the source levels, like when I stream from my phone I can reduce the phone's volume. Or you can do that by lowering the gain on your power amp. Either way you need to turn the preamp up higher to get equivalent output.
To reduce the FM source level, there's an FM level pot on the MPX board. The alignment procedure describes how to set it, but you could always set it lower so that FM is not so booming compared to other sources. Then you can get the volume knob turned a bit more CW.
Good luck.
Good luck.
Hi my mac1900 has a channel louder than other , and when I switch the preamp boards it reverses. So my question is what in the preamp board could cause this issue.
What inputs are you using? Phono or hi level? Is it low for all frquencies, or does it get worse at higher or lower frequency? There could be a lot of reasons this is happening but I'd start by replacing the electrolytic capacitors on the suspect board and see if that changes it. If not, you'll want to check the transistors or get a meter and scope and check bias and see if the voltages look right, or follow the signal with a scope and compare to the other side.
Hi thanks for reply, I am using phono and fm and it is the same on all sources. The 1900 has been fully restored.
By fully restored do you mean the caps are already done? You might check the polarity to be sure they're in right, mistakes happen.
I was asking about the source since phono and FM might use the first half of the preamp while other sources bypass it, it may help isolate to where on the board your issue is.
Does it change behavior when you have filters in / out? That may help you isolate.
You're going to need to get the multimeter and scope out next.
Hi yes all caps were replaced and a lot of other stuff before I got it . I use mainly phono and fm inputs i will try a tape source to see if it is doing it on that . Also my phone has a hum which i have two Mac 1900 one original and one recapped they both hum on phono . I have a Marantz 2270 completely restored on same turntable and cables and it is dead silent as can be no hum on phono .
Bob yes I tried that and when I push in hi or low filter in mutes the left channel considerably.
Bob if the hi and low filters effect the output on left channel which they do . What is the fix for this and I appreciate your knowledge your generously putting out.
If the one channel is low on PH or Tuner but not on other inputs then I'd look at the phono preamp half of the board.
If all channels are affected, the issue has to be in the high level / filter half of the board.
Re: the tone control effect reducing the L channel output, is that now the good channel or the channel that was already low? Either way, I'm not sure the tone controls will help ID the specific part.
I can't tell you specifically which part to go after, that's where you'll need to eval it with the schematic/board drawing, a meter or a scope, and find out where the differences lie, and work where the signal is failing to get through. Check the electrolytic capacitors and the transistors, compare L to R.
The balance control is a dual gang pot. Each pot is a channel and it's wired so signal "in" at one end, signal "out" on center tap. The other terminal of the pot is grounded. The two pots will be wired mirror image from each other. You can figure out which end of each pot is ground b/c those are probably tied together right at the control with a jumper and a black wire to ground. The other outer terminal of each pot is the "in."
To bypass I'd first disconnect the ground and disconnect the ground jumper tying the two pots together. Then I'd jumper each pot's "in" over to its center tap.
That seems straight forward, what do I do with the two grounds I disconnect from the outer pot . If I decide to get rid of the second Mac I will let you know.
I installed a bourns dual 500k pot in the one today it works . The only thing with it is when you turn it to left or right the volume increases alittle more than when it’s in center position. Maybe the resistance is lower in center position. It balances perfect though from left to right . Also the shaft is to short so that may need modification.
I read that the Mac balance control was not good quality , I don’t think so i think it appears to be very well made . I think the problem is people like myself has used the wrong type of cleaner and it removes the carbon off the pads . The burns works but no where near the quality of the original control. I read that C28 balance control will work .
