Reading feedback /square wave results
This type of square wave testing is usually done at 1 watt output, so at that wattage output you could leave the amp on for days at a time with no issues.
I wouldn't do full power square wave testing for more than a minute or two at a time, personally.
Good to know. I feel like that’s rarely mentioned when reading about square wave testing.
That looks much better, but without a schematic it's hard to help you make it better The step attenuator capacitor needs to be increased to bring the first spike a little lower.
If I remember correctly: Transformers do not transform a DC voltage and basically this is what a square wave is.
Having said this, it is good to test the response to transients and this is what square wave testing does. The rule that I was taught is: If the height of the ripple is less than 10% and if the ripple dies out in less than 25% at 1 Khz then all is well. Normal square wave testing was done at 1 Khz and some instability will only show up at full power.
In addition to adjusting the feedback loop other measures may or may not be required. If using UL then you can experiment with a 1 ~ 2.2 Nf capacitor in series with 47 ~ 220 Ohm resistor immediately at the tube socket between plate and screen. If in pentode you can do something similar with ~ 5nF and 5 ~ 20K resistor across the primary of the OPT. Depending on the g1 resisitor of the output tube you can put a 50 ~ 500pF capacitor parallel to it. Watch for a rise in the bass region - this may suggest that the coupling capacitor is too small. On the input tube you may want to add a small capacitor between grid and cathode to curtail the HF , you do not want to feed a transformer a 100Khz signal. There are references to some subsonic sounds contributing to the overal realism therefor a reasonable flat response to about 40 ~ 50 kHz is more than enough.
edit: a link with some scope pictures on what to look for
https://www.angelfire.com/electronic/funwithtubes/T-E-Smith-NFB.html
edit 2: the second and third page of the attached article deals with how to adjust the feedback loop
edit 3: Thanks to s-petersen: (in the posting later than this), a good move is putting a resisitor across the plate resistor of the driver to limit HF response.
I really appreciate the discussion. Just what I was hoping. There are threads that include this type of talk but I couldn't find a particular discussion dedicated to this. Please add more.
John
John
Since you ask here another link: http://www.r-type.org/articles/art-125.htm
On another note: The power supply is an important link in the performance of the amplifier. If not designed properly it can be the cause of a feedback loop from the output to the input. E.g. Many will have: Rectifier - initial smoothing - plate power tubes - resistor feeding cap feeding screen - resistor feeding cap to driver. As a result of not selecting proper values the fluctuating screen voltage can influence the driver voltage. I prefer to split the screen suply and the driver supply, i.e. both being fed from where the plate is being fed. A step further would be stabilizing individually the screen and the driver voltages but imho a tad over the top. In the past often too small smoothing capacitors were used and in some designs where there was too much skimping going on once the capacitors dried out "motor boating" would appear.
edit: and one more: https://www.industrial-electronics.com/ew_1966-03_square.html
(Note: I do not agree with the last remark of oscillation when there is a ripple on the horizontal part of the square wave. Although it might be oscillation more often than not it is just plain ringing from the OPT (if it is a decent quality one). Think about it in another way: when switching on a power transformer you have an initial surge before it settles down due to the magnetizing force in a transformer. The edges of a square wave, what frequency are they at, 1 Mhz, 10 Mhz? Does one really expect no ringing? It is what I once read: The guy stated that he found amplifiers with a perfect square wave dull and if the amplifeir had some ringing he found those just fine. I certainly do not get hung up onto a perfect square wave. I like to test with a triangle waveform too and feed that up to about 40, 50 Khz and observe the shape and size. )
Enjoy, AM.
A bit more trial and error. Upped the cap parallel to the feedback resistor. The overshoot is reduced but the leading edge is more rounded at 10kHz. I'll see how it sounds.
My thoughts were a low pass filter well above the normal audio range, yet not a "wide open" 10kHz square wave. Such as 3x the expected "flat" bandwidth of the amp.
That is exactly what the "shelf" filter does, although it's inside the feedback loop rather than somewhere before it as I think you are proposing. One of the purposes of the shelf filter is exactly as you describe--to offer a low pass filter above the normal audio range, yet not wide open. It does this by lowering the gain of (typically) the first voltage amp stage inside the feedback loop at those frequencies. And that is exactly the effect you are describing.
I think there is some of the same effect that would occur if the square wave were low pass filtered before entering the portion of the circuit with the feedback loop. But I don't think it would address the situation 100% in all cases, including the case of a wildly reactive speaker load, because again, if the amplifier has higher than unity gain at any frequency where the feedback signal phase shift is greater than 180 degrees relative to the signal's input into the portion of the circuit encompassing the feedback loop, the amp will oscillate.
Still, I think it's a worthy of investigation to see how low pass filtering a square wave before entering a global feedback amplifier changes the stability margin and square wave performance.
The step attenuator is not the cap across the feedback resistor, it is basically across the plate resistor of the preamp tube, or phase inverter. It just works on the first overshoot spike.
But that trace looks pretty good as is, if it sounds a little dull, pick a value of cap between what you have, and what was in there last time. Last time how did it sound? I'm guessing a little too bright, maybe fatigueing maybe?
^^^ totally agree, could not have said it better.
Dave Gillespie has been trying to teach me about this, but knows well that I am a "challenged" student. :)
I cobbled together an amp using a Welbourne Labs driver board and Sansui 1000A iron, instead of the usual Dynaco suspects. I had about 6 dB of NFB to begin with. Dave suggested I take the NFB from the 16 ohm winding, which bumped it up to about 8 dB.
The original cap size in the NFB loop (per the schematic) was 100 pF. I "tuned" the cap to try to optimize the 10 kHz square wave (See pics below. Don't worry about the artifacts in my scope trace -- I have an intermittent connection somewhere inside the scope). Using a total of 430 pF got rid of the spike. However, as it turned out, it was oversized. This is what Dave recommends to determine an optimum value:
Feedback Cap Determination
1. Connect the amplifier to a suitable resistive load.
2. Remove bypass cap from NFB loop.
3. Use an oscillator that has constant output regardless of frequency, from 1000 Hz. to 100 kHz.
4. Set the oscillator to 1000 CPS sine wave at a level that produces 1W of audio output from the amplifier, or 0 dB.
5. Increase the frequency of the oscillator until you find the resonant frequency of the output transformer (a bump or rise in output – e.g. @ 62 kHz.)
6. Experiment and select a bypass cap that brings down the response to 0 dB at the resonant frequency.
A 180 pF cap was just enough to bring down the notch to the baseline. The square wave looked worse, although one aspect of the amp had been improved. More work would be needed to figure out the best step network -- pure voodoo from my POV.
I decided to try to dial in 10 dB of NFB as a target for the amp, by lowering the NFB resistor value. The square wave response went further to hell, demonstrating the principle that increasing NFB decreases amp stability.
YMMV.
Yes, but my last mod was in fact the cap parallel to the feedback resistor. I'll work a bit more on it today. Maybe put the feedback resistor back to the previous value and work more on the step attenuator to see what I can do. I changed the step atten cap value but haven't experimented with the resistor.
I'm getting some good learning and intuitive feel from this exercise. So far it's all been trial and error. Now I need to learn the STEPS program that is part of the ARTA system so I can use measurements. Maybe today.
It has been fun so far and I appreciate all the participation.
John
