Richs_Trains
Well-Known Member
Is it working again? In the future, if your leads are on securely, make your adjustments under power. Turning it on/off and making adjustments just leaves too much opportunity for a mistake. As long as your adjustments are minor and your are careful not to short against anything with your screwdriver, you should be able to set it up quickly and easily. Remember to let the unit warm up before making your final adjustments. Good luck! Rich
