Quadman2
Lunatic Member
...I can not find a place to buy the service manual.
Found "three sources" for that 2033, using "service manual for Sanyo 2033?" and one on "Ebay".
Q
I would love to but I do not have the training or knowledge to do that. that is why I have been replacing parts. Since the problem exists with any input I assume it is in the main board and not the FM Board etc.Anyway, replacing a lot of parts without a diagnosis can introduce more variables and more things you can't trust. The proper way to solve a problem is to trace the fail and narrow the problem to a small area. As you say, you already replaced many parts and the problem is still there. There are many ways to trace a fail. I'd start checking voltages and tracing the signal with a probe, sending it to a 2nd amplifier.
Even if I built it, I would not know how to use it. I already explained several times that I have no training in electronics. Everything that I have repaired was thru replacing parts. Even mechanics these days are not mechanics. they are parts installers. This is a simple simple issue that an electronics expert could diagnose if they read this and could of told me what to replace by now.Please, try to follow my graphic instruction to build an audio tracer probe, and then ask here to follow the signal inside the amplifier. If you are able to solder and desolder components, and disassemble
With all due respect, if it was that simple and someone knew exactly what to replace they probably would have told you by now.This is a simple simple issue that an electronics expert could diagnose if they read this and could of told me what to replace by now.
You understand any "new" STK you buy is almost certainly going to be a counterfeit part, regardless what the seller may claim, right?So the STK amplifiers it is.
I will remove and test them first just like all the other parts I removed.You understand any "new" STK you buy is almost certainly going to be a counterfeit part, regardless what the seller may claim, right?
An original STK is not a part to replace unless you're sure.
Instructions are in the very first sticky (pinned) thread in the "Digital Docs" subforum.PSTDEcat, was kind enough to e-mail me the Service manual for this Sanyo 2033. I have tried to save it and post it here but it says the file is too big. If anyone knows how to post it or save it one Audiokarma in the section where you post it, please let me know and I can e-mail it to you.
