stageninja21
Hello all,
New to audio world, working on adding a Realistic APM-500 power meter to the first system I'm setting up. My old speakers have RCA plugs and the APM uses spring terminals. I'll be connecting all my components to a splitter since I have multiple input devices, splitter also has RCA jacks.
My noob question is, what's the best way to connect the APM since it does not have RCA plugs? Should I get a set of RCA to spring terminal connectors and cut off the RCA plugs from the speaker wires? I assume I'd be able to fit both the speaker wire and the wire from the APM into the spring connector hole but I'm not sure if that's the best way. Is there some sort of RCA tap that would be better?
Sorry if this is a basic question, but I really want to do this right since I have limited cash and don't want to break anything with my lack of knowledge /experience. Have prowled around this forum for info before and i figured y'all would be able to give me the best answer
