Realistic ATN 771F
Hawker1
I’m having some trouble finding out anything about this cartridge and stylus, any help would be appreciated. Specifically, who makes (made) it? What would be the equivalent model in the on-brand line-up? And any opinions you might have. It seems low-middle end, is in great shape and sounds just fine on a PL-540.20201007_073043.jpg
Post this in the turntable forum and I'll bet someone will be able to tell you what AT cartridge it is. This will help you to find a suitable replacement stylus. Realistic used many ADC, Shure and AT cartridges just rebranded.
Thanks people. I thought it might be AT, there seems to be a symbol (albeit a faded one) that resembles the AT mark. I’ll post in tt’s as you suggest for further. Thanks again.
Hawker1: An ATN-771F would ne unknown to me. Could it be, that the visor guard is covering a part of the inscription? Because that should rather be an ATN-771E. The AT77x models were variants of the AT7x models with additional visor guard, but otherwise technically the same.
Greetings from Munich!
Manfred / lini
Probably an A
Manfred / lini
Realistic put there own numbers on the cartridges they used. Sometimes very close the the same number as the manufacturer. They used a lot of Sure cartridges. It does look like its a AT71E. They also used ADC cartridges on some of the BSR turntables they sold under the LAB label.
Later they started using AT cartridges. Realistic sold a lot of rebranded stuff.
Lavane: Yes, but that's not only a rebrand, but also a slight variation of the AT(N)71E due to the additional visor guard. There also was an ATN771 variant of the ATN71 without the additional Realistic and neelde type inscriptions - see for example there: https://www.thakker.eu/tonnadeln/audio-technica-atn-771-nadel-fuer-at-771-original/a-6120/ As you can see, that's also a variant with additional visor guard, but the front label design doesn't really differ from a regular ATN71.
Manfred / lini
