Brivan
Well-Known Member
I own several pairs of Realistic Minimus 7 Walnut speakers - many of which have the dreaded broken plastic grille guides. I poked around on AK, but didn't find a mod to alleviate this perpetual problem, so I came up with one. I ordered grille guides from Parts Express, part number 260-366. Here's what I did:
Remove the speakers and insulation
Break off the remaining tabs of the existing grille guide pins.
Drill a 1/16" pilot hole in the middle of each pin. When drilling holes, use the drill's lowest speed range and drill very slowly without exerting much downward force.
Drill a #7 hole in each pin. This will get the hole very close to the diameter of the existing pin. The pin might push or pull out with the drill bit. It will probably be necessary to hold the flange of the pin in place while drilling this hole, since the pin might try to spin.
All pins have been removed. Notice this speaker had some previous issues with the lower left-hand grille guide pin - it looks like the laminate was slightly lifted and glue was used by the previous owner to hold the pin in place.
When enlarging the holes beyond this point, use something (tip of needle-nose pliers here) to hold down the corner of the laminate to prevent it from lifting while being drilled.
Holes have been enlarged using a two step-process - first with a 9/32 drill bit, then finishing with a 23/64 drill bit.
Black furniture marker used to darken some of the light areas that the new grille guide flange might not cover.
New grille guides installed using a small amount of adhesive to hold them in place. This is optional, as the guides will fit in pretty snugly.
