videolady201
AK Member-Design Engineer
Please Explain
If you wire the mids this way, you just removed the bandpass and created a 4th order high-pass for the mids. This will allow the mids and the tweeter to operate over the same range and create lobbing effects. So, you converted the bandpass into a highpass, why? :scratch2:
I did the new crossover for my Optimus 5B (per the VL diagram) and listened to the results. Well, it sounded different than the original, but there was no WOW. The bass was fuller & deeper, but I attributed that to better sealing of the cab. The mids & highs didn't really sound like a speaker "transformed".
Later, I happened to come across a schematic for a three way speaker and noticed that the mid-range (bandpass) network for the VL Nova 8b mod didn't make sense.
What did make sense was having the 2.7uF cap as the first component, with the 2.0mH inductor as the shunt to ground after that, followed by the smaller 1.74uF cap in series and the 1.0mH inductor as the shunt to ground after that.
. Across the board, they do everything better than the stock speaker. Enough so that I'm actually considering putting some better quality caps in there to see if I can take it up another notch :scratch2:
