Elliot Thompson
Well-Known Member
I have a pair of 5's (not b) and I may be interested in this mod. I'd have to check to make sure the drivers are the same as the 8b (I'm pretty sure the woofer is). My problems are:
1. The tweeters on mine are dead- currently using some vifa domes. Would the vifa's work in this case or should I hunt for the original tweeters?
2. I've never assembled a cross-over before so I would need a lot of hand-holding.
3. If they sound as good as you say I would have to re-laminate my cabinets as they look pretty bad now (my problem).
I have to say with the new capacitors and the vifa tweeters I put in these Optimus 5's they sound pretty good. If they improve as you say then sounds like they are one heck of a speaker after the mods.
Tiga
Hi.
I own the Nova 5 which are used for computer speakers.
The original tweeter offered a frequency response of 20,000 kHz. Providing your Vifa tweeters offer the same frequency response, they should be fine.
I would not recomend getting caught up in looking for tweeters that offer a higher response than 20,000 kHz if your Vifa tweeters cannot achieve 20,000 kHz.
There needs to be a proper balance between the woofer and tweeter which the frequency response amongst both drivers play a factor on the overall sound.
If you prefer the original tweeters, try searching Ebay for some Nova 5 speakers. I believe I picked up mine for $15.00 in 2002.
Best Regards,
