Realistic Optimus 5 Upgrade Help
Darkcrusade1
I have a pair of Realistic Optimus 5 speakers, the crossover is fine and I may rebuild it later. The real problem is that the tweeters are blown on both sides and I thought instead of finding replacements from a speaker that has been parted out, I might as well just upgrade the entire cabinet with new budget Hi Fi gear. The tweeters and mid range faceplates are 4.25 inches in diameter, and the woofer is about 12 inches. After some research I learned that the mid ranges are setup in parallel. Just need some help on replacement parts, this is my first upgrade to a set of speakers. I'm looking for around a 40 Watt or above setup.
