Francis55
All,
I just picked up a pair of Realistic Optimus T-100 speakers for $20
. Hooked them up, tweeters seem dead. Just checking that I'm wiring them correctly. This is a dumb question, but does that silver barrel, across from the wire terminals, need to be hooked up at all? Just checking! See picture. That would require a third connection, so I thought maybe that's why tweeters are silent. More likely is that they are just dead and need to be replaced. If I'm replacing them, ideas for what would be a good substitute? Many thanks for any ideas you guys might have!
Francis
. Hooked them up, tweeters seem dead. Just checking that I'm wiring them correctly. This is a dumb question, but does that silver barrel, across from the wire terminals, need to be hooked up at all? Just checking! See picture. That would require a third connection, so I thought maybe that's why tweeters are silent. More likely is that they are just dead and need to be replaced. If I'm replacing them, ideas for what would be a good substitute? Many thanks for any ideas you guys might have!Francis
