rs732
Hello AKers,
I have a Realistic Lab-420 TT that has the RCA cables and the power cord cut off. I replaced the power cord. Also, I attempted to solder new component cables where the original RCA cables were cut. They worked before soldering, but one channel stopped functioning after the soldering. I don't have much more of the original rca wire to risk another soldering attempt. Therefore, i was thinking if i should just solder an RCA type plug to the original cut wires,so i can plug in rca cables.
I seen a post on here before about doing the upgrade,but can't seem to find the post. Does anyone know what this RCA adapter/plug is called? Also,any advice on how to mount the plug/adapter to the turntable?
Thanks AK
You guys are always a big help!
Thanks AK
