Picked up a Realistic SA-2001 on Craigslist that is unfortunately wired for use in Europe/Australia at 220 volts. Operation of the unit is unknown. Based on what I have found through some research about the amp, here are my questions and findings that I need help with.
I'm thinking that I have these options:
* Buy a step-up transformer so I can see if the amp is hopefully operational. I'm thinking a 1000w would be sufficient. The SA-2001 is rated at 340w.
* Wait for a "parts" item on Ebay for a working 110v transformer to replace the 220v one. According to the service manual the Realistic SA-2000 and SA-2001 share the same power transformer.
* Inside my SA-2001, the 220v transformer(pictured below) has 2 primary wired taps, 1 white(used) and 1 that is unused and protected by black heat shrink. Can anyone tell me if that unused wire tap is indeed a 110v wire that I could use to convert the SA-2001 to 110v thus allowing me the best option,maybe.
Thanks to anyone that can help me.
