polypetalous
I love my vintage Realistic setup.. but, boy does it like to keep my guessing.
Realistic STA-2000
Been having intermittent Speaker Protection Relay issues...
About once every couple of weeks, I will encounter an issue where the protection relay will engage/disengage say every 5-minutes or so. But every other time the Receiver will run flawlessly for hours, days etc.
I have really wanted to check voltages at the protection boards when the relay WONT engage, but every time I try to take the unit apart to check, by the time I get there the relay has re-engaged and is working.
But that being said, when the unit is functioning here are the voltages I get on the protection board at (what I think) are the in voltage and out voltage pins of the protection board.
Protection Board
Pin #1 - Right Channel IN ~16 DC Volts
Pin #2 - Left Channel IN ~ 9 DC Volts
Pin #3 - Right Channel OUT ~10 DC Volts
Pin #4 - Left Channel OUT ~6 DC Volts
I suspect BOTH L & R In/out should be the same. And again the above readings was while the unit was functioning.
So my initial thought is RIGHT AMP board has gone awry and is probably showing HIGHER voltage when the relay disengages.
But I honestly DON'T know what the correct voltages here should be.
I dont know if this is a AMP board recap, a Protection board recap, power supply recap or the whole enchilada, or something else all together.
Would love anyones thoughts, input, anecdotes etc.
Thanks in advance.
Ben
Realistic STA-2000
Protection Board
Thanks in advance.
Ben
