Realistic STA-2080 in protect mode
toler8
I'm an interested & enthusiastic novice when it comes to electronics but my knowledge is basic to say the least, hence why iv'e posted here in the hope you guys will help me through this issue and hopefully i'll learn along the way.
Iv'e been restoring this receiver, so far all switches and pots cleaned with deoxit & faderlube, the power supply, protection board and main amp boards have been recapped by following a restoration thread on AK.
Upon completing each board i tested using the DBT and tried music through it everytime, i also took voltage measurements from the boards before and after. It was sounding great but the problem came when i changed the trimmer pots on the protection board, i thought i had set them correctly to the old ones but obviously i couldn't have. Upon powering up on the DBT r615 on the power board smoked, i quickly turned off. when i removed r615 it was split in half.
I'm certain this would have took other components out, i would appreciate any guidance given to help with this and hope to learn along the way.
Segment of schematic attached
R615 provides power to the speaker relays and the protection circuit.. The trimmers on the the protection board are for calibrating the meters. Neither one has anything to do with the other. Check the parts you replaced for proper polarity and looks for solder bridges.
Craig
Thank you Craig, the relays click out of protection now.
There were a couple of solder joints that under brighter light looked cold, I had checked before but on your suggestion gave the boards a thorough inspection.
However, the watt meters aren't working,they were previously. Is it possible by having the trimmers set incorrectly I may have damaged the ic?
