Stereoboy70
Hello All. Question..... I’m replacing the transistors on both amps in my 2100D. The service manual shows different layouts for the 507 and 508 transistors. The pic of the L amp shows. B C E but the right shows E C B
I’m replacing with MJE 15032 and 15033 which are B C E. The actual amp board shows. E C B. So do I put these new ones in backwards ???? If I do the heat sinks will not be in a position to accept the screws that hold them to the board. A little confused.
