Live_Wire
Realistic Ak'er
(Solved) Realistic STA-2100D Weak Right Channel
After a couple hours of listening and messing around, I noticed the right channel sounds a little weak compared to the left. At lower volumes, the right channel starts to distort a little too. When you turn the volume up a little (to about 0.5 watt) it goes back to normal. I thought it was just the attenuator switch, but I ruled that out. I turned the volume down to the point where it started to distort with the attenuator in, then I tried wiggling the button and it didn't change. As soon as I turned up the volume a little, it came back. I also did this with the loudness button and bass control.
Now, my question is, what can cause this? I have checked the DC offset, and I'm getting 4.5mV on the right, and 4.6mV on the left channel. I haven't checked Bias yet, but I just got the service manual. I will check that tomorrow. I'm wondering if the filter capacitors would cause this.
Any ideas to help point me in the right direction?
