JB8
Well-Known Member
Squad,
I've been on a little run of finding and replacing bad transistors this last week and brought three units back to life thanks to your help - a Concept 2.5, HK 330c, and most recently I've been working on an AA-6600 that's close to being done, so I thought I'd pull out a STA-78 I'd been working on last year but shelved the project because I couldn't track down a bad transistor. I pulled it out today and found/replaced the bad dudes in record time, again, thanks to this forum.
Backstory: I've replaced the main filter caps, power supply caps and the caps on the tone phono board. Today after replacing the three transistors in the picture (TR601, TR603 and TR605) the receiver is singing like a bird and is dead silent with volume at zero, sweet! (I also hard wired the meter light into the main array along with installing a 47 ohm resistor to help accommodate the LED's)
Issue: No stereo light even with stations coming in nice in stereo - in other words, I'm hearing it, just not seeing it.
I pulled the old LED and couldn't get it to light up when removed from the unit, but also attached another new LED to the leads and it wouldn't light up either even though I know it's a good lamp.
Here are a few voltages from the power supply:
8) .03 v
9) .50 v (when tuned into known, strong stereo signal)
13) Pre 35.25 v
14) Tone 36.50 v
15) +B 29 v
16) -B 29 v
With the voltage higher than ideal on 14 (should be 29 v) is is safe to think the issue may be with TR701 or I'm I way off?
Any advice is much appreciated!
WARNING: I'm still pretty new to the scene and I ask some pretty dumb questions, so thanks in advance for your patience.
8) .03 v
13) Pre 35.25 v
14) Tone 36.50 v
15) +B 29 v
16) -B 29 v
