realistic STA 850
Vehto
hello
Picked up a realistic STA receiver tryiing replace bad transistor I have no schematic
part number on transistor is D1046 ita an audio out put transistor one of four
can anyone supply a cross or real part no
any help will be appreciated
Realistic is Radio Shack brand. Doesn't Radio Shack have a cross refference? Normal practice is that you should replace output transistors in pairs. If one is shorted, say in the left channel, then you should replace both in the left channel. My cross refference book is buried in storage somewhere, so maybe someone else will come up with something! PS, also check the driver transistor in the same channel the bad one came out of.
Thanks Cademan I will check the driver tonight bad trans is shorted at EC
pop a fuse play fine for a couple of days goodwill fine. great tuner !! 50 wpc
I think its worth fixing
No Luck at RatShack anyone with information on the reciever Please help
Thanks ! STA-850 sku 31-2096
vehto,
Sometimes adding 2S to the number will give you the part number,
Like 2SD1046 see if this helps.
Barney
