Impact
Looks like il be adding to the fun as I am as well a STA78 owner that has crackling/popping out of only the left channel. After searching the forums, I put together that this is likely a bad transistor and decided to start doing a cold test of the transistors using super cold spray.
During testing I was just narrowing down the exact transistor that was giving me the left channel noise issue and suddenly the crackling noise was gone. Issue was I had about 3 transistors cold so im not sure which one is the exact one that is blown. (Noob mistake)
Then suddenly before I had a chance to do anymore testing my speakers start squealing like a baby in a doctors office. Extremely high pitched noise that did not go away with volume/input controls. I turned the unit off and unplugged it to find my R623 resistor smoking away and black.
I'm relatively new to this so I may be guessing wrong, but it seems that R623 resistor likely was overloaded and blew due to the transistor that I am actively trying to troubleshoot. My suspected transistors are TR602, TR604, TR606, TR608 but they are all a long way away on the board. Not sure if this theory makes sense or if I have other issues. Just looking for any advice/input before I try to just order a bunch of new transistors.
Photo attached to provide a visual. Bad resistor is marked in red.
