I think I would try spraying the output transistors with freeze spray. I have seen those TO-220 transistors go noisy.
I find that almost any component causing noise can be affected by heating or cooling. You can spray whole areas of the board while troubleshooting. You can even spray the back side of the PC board in areas (which cools the components through the leads), to see if it effects the noise. Be a little careful if you get condensation on the PC board. If you get much condensation, it is wise to turn the unit off until it dries (as it can cause high current issues in the power amp circuit). You could also use a hair dryer to heat areas of the board, to see if it will effect the noise.
