Hello, after a 3 day fight I gave up. My sx-750 started to generate a very quiet but audible hum mixed with some white noise on both L and R speakers. Not volume dependant. Unit is cleaned and fully recapped, worked for some time with no issues at all.
I unplugged L and R signal posts on amp pcb to check if it's still there - it is, so it's not a preamp, vol or tone control issue.
I replaced 2sc945 transistors on power supply board, tested all 3 to-220 transistors, replaced 330uF 50V caps with 470uF 63V, tested 3 zener diodes, (13,7V, 24,6V drops on negative line, 13,8V on positive). Added 4700uF caps in parallel to main filter caps - nothing better.
Voltage on pins 16 and 18 seem to be uneven.
Pin 16: -41V
Pin 18: 39,6V
I'm using dbt and my power line is 220V at the moment, but due to PV installations allaround I switched the unit to 240V as my power line exceeds 240V on sunny days.
I scoped the speaker outputs, both seem to have 50hz with some white noise distortion that's audible, it's about 15-20mV. It's new to me toy, so if I have to make any oscillograms for further analysis, I need some instructions.
Any help will be greatly appreciated.
Pin 16: -41V
Pin 18: 39,6V
