jhal
Titanium Bliss
I pulled the woofers out of my DM2 mark II's to make a parts list of caps. I am going to recap them to see if it helps tame the metallic-sounding high's it has developed. I first thought my amp was having problems, but it sounds fine through the headphone jacks and some other speakers. I definately think the crossover point for the tweeter has drifted lower than it should be. The woofers are stamped "NOV 22 1978, so they just turned 29. The caps in question are electrolytic and I would like to upgrade them. I need to find a source for these caps since Parts Express doesn't have all of the values I need which are, per speaker:
75uf 50v
80uf 25v
15uf 25v
30uf 50v
20uf 70v
I also want to upgrade the internal wiring used since it is about 22AWG. Can anyone make a recommendation or point me to a source to obtain these? Can I step up to polypropylene and retain the same characteristic or should I stick to new electrolytics and leave well enough alone? Thanks for any and all input, John.
75uf 50v
80uf 25v
15uf 25v
30uf 50v
20uf 70v
