Recapping for hecos...questions
marloubow
Best Day Ever
Hi all!
I need to make sure that I'm replacing these caps correctly.
"MFD" is the same as "uF"...correct? So according to the photos I need (per speaker) 1-10uF 35, volt or higher,
1-3.3uF, 35 volt or higher,
1-25uf, 50 volt or higher.
Do the "+" at each end mean that they are non polar.
What type of caps are they (ie, non polar etc)?
Thanks :thmbsp:
Martin
Yes, MFD is the same as uF. The "+" at one end mean that they are polar. Take a look on partsexpress.com, you should find what you need.
Thanks tgunner...
The pictures indicate a "+" at each end.
So at the risk of being redundant :blah: Does that indicate non polar?
Thanks
Martin
Thanks Sir.Byrd
Since no one has mentioned it, I''m assuming that my values are correct?
Should I look for a better quality of caps rather than a equal replacement since these source fairly cheaply?
Thanks
Martin
Unfamiliar with your speakers... for general quality speakers (I.E. not worth over $1000) I use Dayton 1% metalized poly caps from partsexpress.com
