Are you talking about a TR 2080? There was no 1080...
I have to question the sanity of anyone that would blindly modify what is possibly one of the best-sounding receivers of all time... do you really think you as a relative amateur are going to make this design sound better than it did as delivered by some of the best engineers in the audio industry?
I know everyone likes to think "oh, we have better quality parts now" and "oh, they would have used these if they knew about them or if cost constraints didn't make it impractical" etc.
The reality is, those technologies were not unknown when the 2080 was designed, and at $1100-$1200 retail they had a HUGE cost budget. They also had training, resources, and experience that virtually no modern DIYer is likely to be able to match. They also had controlled high-quality production capabilities that resulted in reliable products, not something the average DIYer can lay claim to. When you modify, you raise the failure rate sure as shootin'.
To me, assuming you will make a product (that works as well as the 2080 does) work better simply by upgrading some of the components - without ANY modeling or circuit analysis - is insane and smacks hugely of hubris.
However, I understand that some audiophiles simply can't enjoy the equipment unless they tweak or modify it almost beyond recognition. For me, I'll take the unmolested original every time.
If you are simply replacing aged electrolytics that have lost capacity or dried out over time and are measurably impacting performance, that's one thing. To replace or "upgrade" every cap in the signal path in the blind assumption it will somehow sound better is not supported by logic or science. I'd love to see some double-blind listening comparisons between original versions of some world-class audio gear, and recapped versions.
Don't fix it if it ain't broke!
John
Looking for some recommendations on recapping the Tandberg TR1080.
After reviewing the schematic it appears that Tandberg coupled the preamp stages with caps and are not direct coupled like todays amps. So, choosing the right cap will make a huge difference in the sound. I have used Nichicon PW caps with great results but never tried them in the signal path.
You opinions and experiences would be appreciated.
