I am beginning a new project regarding my 30+ year old receiver I have owned since day one. Due to amp in one channel going out I openned the case up and found a number of blown caps in the audio and tuner boards. I will be purchasing a new intergrated amp shortly, but I want to "play" around with my NAD just for experience sake.
I gotten the boards seperated from the case and will be sending for replacement caps (Mostly Elna caps) - however, I need advice on how to best remove the caps from the board - When one turns over the board there are no indicators on the board what device is on the other side - I do not want to be de-soldering any other item than caps - so how does one go about removing the caps without mistakenly desolders some othe device, say like a transistor?
I have downloaded the service manual but I do not find it to be much assisstance with helping to locate the caps from the underside - any recommendations as to best method??
