Received my pcl-S Denon S arm / head shell
I_Wanna_Rock
OK I received my Denon S arm today and also the head shell that I purchased. I’m not sure if I’ve got the right one, (head shell) though. I’ve only had a straight arm since I’ve owned the system, here’s some pics…, help please! The head shell is from LP Gear, it’s the “Zupreme head shell”. I’m still green about a lot! :/ Seems like the head shell should just pop into the arm? But I thought I’d ask. :)
So this is a set screw on the arm itself?
I meant tightening the part on the arm tube that "seems to spin". A spiral track inside pulls on the vertical pin. The set screws visible on the arm tube just hold the ends in, I believe. If your headshell has adjustable azimuth ('tilt'), the screw on the bottom of the headshell clamps around the barrel, which is allowed to turn when loose.
Okay, it’s playing! The eagle has landed!! To the Bat Cave!!!
DP57L, pcl-s arm, Nagaoka mp200, Zupreme head shell
