We all know that the specification from Mcintosh amplifiers are very conservative. One example for this is the MC 452, which is rated 450 Watts per channel in 2,4 and 8 Ohms.
As you can sea in a review from a italian audio magazine the meassured data are far more higher. The came up with a maximum of 2*1.186 Watts in 4 Ohms. Also very interesting that they tested the power for every connection (2,4 and 8 Ohm connection).
Here is the link: http://www.mpielectronic.com/NewsFiles/McIntosch C50-MC452_AR-Giugno2011.pdf
What is more important, that the specified data from Mcintosh from 450 Watts in 2,4 and 8 Ohms are only possible if you switch the 2,4 and 8 Ohm connectors. But this is not very practical and we all know that the impedance curve of a loudspeaker will never be flat.
For that reason my proposal to improve the literatur data.
It would be very nice and helpful, if Mcintosh can specifie the power output for every connection. For example:
8 Ohm connector has 450 Watt on 8 Ohms; 600 Watt on 4 Ohms and 300 Watts on 2 Ohms.
4 Ohm connector has 300 Watt on 8 Ohms; 450 Watt on 4 Ohms and 550 Watts on 2 Ohms.
2 Ohm connector has 150Watt on 8 Ohms; 300 Watt on 4 Ohms and 450 Watts on 2 Ohms.
What do you think Ron, could this be possible?
Bye
Martin
Bye
Martin
