Recommend me speakers for...
34dean
AK Subscriber
I just picked up two vintage receivers and I am looking for a great pair of similar era speakers. Need them to be highly efficient. I am leaning hard toward Klipsch Hereseys but I am open to recommendations of all manufacturers.
Receivers: Luxman R-1070
Harman Kardon 430
Thank you in advance!
Why do you need them to be highly efficient? Most speakers, even low efficiency ones, can play fairly loud in normal rooms. Obviously the 430 is no monster receiver, but it satisfied a lot of people back when low efficiency speakers were the norm.
And recognize that one way to achieve high efficiency is to limit low frequencies - it is bass that requires lots of power (or enclosure volume, and lots of it). The Heresiess are are a good example of this - they appeal to a lot of people because of their dynamics and power handling, but no one has ever accused them of having lots of bass for a box that size. You can ameliorate the lack of deep bass with a powered subwoofer, but once you accept the use of one, practically any speaker, freed of having to move lots of air, will be efficient enough.
Another way to achieve high efficiency is to have lots of peaks in the frequency response - speakers often are less efficient because the designer has chosen to minimize resonant peaks - its more difficult to boost specific frequencies than it is to cut them. But peaky response can be unpleasant - though if the peaks mate with your room, the result may be relatively flatter and easier to listen to.
In general, speakers are very much a matter of individual taste. Choosing them on the basis of efficiency is unlikely to satisfy you long term since it addresses only one of the myriad of factors that make up sound, and our response to it.
Having said that, you may be a Heresy lover, in which case, you have your answer. But if you haven't heard them, and over a fairly long period of listening, it might behoove you to arrange a listening session before forking over your money.
Heresies are fairly often offered here, and there is a lot of information about modifications to Klipschs out there, and posting your location might help find what you want, or someone to help.
I sort of assumed high efficiencies would work best for the HK. Perhaps I don't need that. I am looking for the best match for these two receivers. I typically like accurate, punchy sound with crsp highs and decent balanced bass.
You're right that a modest powered receiver will probably work best with relatively efficient speakers, but that describes many, if not most, speakers. There are obviously exceptions, but in some cases, the issue is not that a speaker is inefficient, but that it is a difficult speaker to driver. Speaker loads are not just resistive, but are also inductive and capacitative, and the nominal impedance of a speaker is just an average. Some speakers have punishingly low impedances at specific frequencies, close to dead shorts, and many amps cannot handle such a load, particularly amps that were designed to look powerful into a resistor (which is how FTC ratings are measured). Your HK is much more load tolerant that many recievers, and may play louder and cleaner than amplifiers that look more powerful on paper.
Harman Kardon 430
The Harman Kardon 430 works very well with the Heresey. Very common match used to tame the flaming Heresey.
This would be the result of the 430/Heresey match.
Don't match Yamaha to Heresey.
Harman Kardon 430
The Heresy is an awesome speaker, there's a reason it has remained virtually unchanged for 6 decades. If set up correctly it has ample punchy bass, IE sitting on the floor, near the front wall, not toed in. I prefer them with spikes on the bottom if set up this way, further tightens up the bass.
But for best imaging they should be raised off the floor and moved away from the front wall, bass will suffer a bit. I found a pair of Dayton Audio Sub 1200's make perfect stands putting them at tge correct height, and giving 25hz capability. Connected in stereo preserves the Heresy sound only BIGGER, and here's the best part, the Dayton sub is only $139 lol.
So along with the cost of a set of used Heresys you get a killer set of speakers for a grand total of $700, you won't be disappointed. But who knows, you may be satisfied with the Heresy as is as so many before you are.
Have you heard the Heresies? In the context of a question posed about Heresies, your description of what you are looking for sounds rather like a thumbnail of them, but, truth be told, all speakers claim those qualities, and probably most listeners claim to want something like it. If you have heard them, and you really liked them, then your search may be over - you can always add subwoofers and Crites mods if your tastes shift. And if your tastes shift a lot, one unassailable virtue of the Heresies is that they hold their value better than many speakers - there are always people who want them.
Check out DC offset on the H/K before spending 700$ on speakers.... No relay protction on these.
If efficient, I would go for upper suggestions as Cerwin Vega D3 to D9. Party loud
More refined for my ears : Celestion Ditton 22, 33 or UL6 - B&W DM2.
Depends on your listening level habits and room config.
