Recommendations For Phono Preamp
Don't stop there, tell me more. What are you thought/impressions, and is it ss or tube, are you completely satisfied or looking to upgrade in the future?
It's a solid state unit. I own one as well, and it sounds pretty good. I've compared it with a Clearaudio Nano and a Musical Surroundings Phonomena II and holds it own with either.
There's also a tube version, The Tube Box S.
It's not a kit.
jeff
Do you own this unit yourself, how long have you had it in your system, and what are your thoughts/impressions?
What table/cart are you using, have you own any LOMC you could share?
I don't own one, but I do have a Piccolo, the original version built from the 1/2 kit that was available at the time. Jim designs and builds good sounding products, especially for the money. The Bugle 2 has a very good internet reputation.
A friend here has the Cornet 2, also built from the kit that has been discontinued. It's a very nice sounding phono stage.
jeff
jeff
I looked at the website and the reviews were amazing. The unit can be built with 40Hz, 50Hz, or 60Hz. Can you help me disect the one that I would need, and why do they offer three versions?
It's dB, not Hz. You choose the desired gain to match your cartridges output voltage. "Gain can be set for 40dB (moving magnet, >2mV), 50dB (Denon, 1.5mV), or 60dB (moving coil, <1mV)."
jeff
Looks like the Bugle2 is out of the question. I received an email from Jim, and basically I will have to buy one of each configuration for my needs. Out of the question.
Back to square one. I'm open to any/all recommendations, but it must have dip switches on the outside, not inside, to make it easier to use.
Make/Model is irrelevant. 90 to 92dB is quite enough and more efficient to handle anything. They had a MSRP of $1,000, but that is not what I paid... ;)
Unfortunately that is so wrong, unless you think all speakers sound the same !
However, since you've given a price, I wouldn't go over the $150 mark, since it's unlikely you'll hear much difference.
How do you folks feel about the Emotiva? https://emotiva.com/products/pres-and-pros/xps-1
MM or MC and those fiddly dip switches are at least on the outside top of the box so you can easily experiment. It's at a reasonable price too.
I'm using one of the Emotiva preamps with an Audio Technica AT-OC9/II LOMC. I'm currently using the MM side of the preamp only with an AT-630 SUT. Sounds amazing. I use the Phono Box S with a Denon DL301mkII LOMC with excellent results. Synergy plays a huge role with different combinations.
I know someone who had the XPS-1. For the first year all was good until a problem occurred. He contacted Emotiva and they sent him a new walwart. In his words this was a band aid fix, not a true fix. I think it was about six months when the unit quit working properly. He contacted Emotiva again but no help. They would not do the right thing in helping resolve the issue.
I would not recommend Emotiva as an option.
