Not sure if these suffer from the notorious noisy transistors.
Not usually.
Sorry, that was the end of my post. I asked to help me with the following:I'm sure that this top amp must be definetely dead silent.
Hi! Thank you very much for your comment.I am understanding from your post that you are experiencing two kinds of noise from your Sansui AU-919, transformer noise and audible noise from the speakers. Is this correct?
Transformer Noise: Have you put your ear near the transformer and you can physically hear it humming? If it is physical transformer hum caused by vibration of the transformer it can be because the glue inside the transformer windings is coming loose with age or it could be because the idle voltage is set incorrectly, causing the transformer to hum (or some combination of these things). Sometimes tightening the mounting screws on the transformer can lessen the vibration but may not fix the underlying problem of why it is vibrating.
Audible Noise from Speakers: What does the noise coming out of the speakers sound like?
The thing is that I've bought this amp as damaged (it had been fallen down from the table) with the burned transistors in the preamp stage.
Thank you very much for your attention! Let me some time to investigate all the ground-to-chassis points and I'll come back with the results. Also please advise would be JBL4311(L100) a nice pair to 919 (my current speakers are the vintage SABA Pro1300)?I'd be looking really hard for physical damage to the unit then since it is known to have taken a big fall. Look really hard at the ground points where the circuit boards solder and connect on to chassis ground. Press on those points with something non-conductive to see if there are any cracked or bad ground joints. With AC hum like that, a bad ground connection somewhere can be the fault, especially now knowing the history of the unit.
