I'm a toob noob, so looking for some advice on a potential 1st tube project. I have an opportunity to buy a couple of 100W Bogen Challenger PA amp chassis (no tubes) for $25 ea to use as a base for building a couple of monoblocks. I've seen some positive comments from others that have done such a conversion, so it sounds promising. I'm just wondering if I might I be better off starting with a different approach as a first tube project, like building something from scratch, or starting with something like a stereo Magnavox chassis.
The Bogen chassis is attractive because it seems to have fairly beefy output transformers and could provide decent output power (maybe 40W at reasonable fidelity?), but each uses four 7868 power tubes, so a little pricey. If I went the Bogen route, I'd probably just bypass the tone and input sections for stage 1 of the project, and maybe later work on the preamp section (I would eventually like to have a good phono input).
I should probably mention that my power needs are low-moderate, as I would be using the amps in a small room. The Bogens might be more power than I need, but I figured, why not? (aside from the higher cost).
Anyway, any advice would be appreciated.
P.S. Guess I should also mention that I'm an electrical engineer, but my career has been spent in the digital domain. Looking to do something a bit more fun now!
