Recommended Power Conditioner & Surge Protector?
Sanc
I'm Hiding in Honduras
Hey all,
I am moving into a new apartment building in the next two weeks and unfortunately the building's wiring and power overall is not the cleanest, so I would like to purchase a power conditioner that also functions as a surge protector. I have very little experience with this kind of equipment so a point in the right direction would be highly appreciated. Not trying to spend a fortune, $200-$400 is my range.
I would have the following 8 devices hooked up to it...
1. Musical Hall Cruise Control 2.0 external Turntable PSU and Speed Controller
2. Marantz 170dc amp
3. Marants 3250 pre amp
4. Grant Fidelity TubeDAC11
5. Musical Surroundings Nova Phenomenon Phono Pre
6. Squeezebox Touch
7. External Enclosure for HDD music storage device.
8. Eventually an SACD player.
Does it make sense to get a conditioner that can function as a surge protector as well, or get a dedicated surge protector and a power conditioner? I've never had to research this as my current home actually has quite clean power so it's never been an issue.
Thanks for your help,
Matt
Furman, Belkin or Panamax would be my recommendations.
I have two Panamax M5400's and they work great. They operate as surge protection and power conditioning. They've absorbed a couple of spikes that I remember seeing while the system was running. Not necessarily in your budget limitations, however, unless you find a good used one.
I use a Belkin upstairs I found used on eBay for $75 that works as a surge protector and power conditioner as well.
+1 on Furman and Panamax, they're the class acts in this category. A large part of their business is commercial applications. (At one time AT&T was Panamax's biggest customer)
Happy trails,
Larry B.
At some point Panamax and Furman merged companies. Either one will provide all the protection you need.
That's true. They still market both brand names as I believe they individually focused their products on certain industries and have a branding recognition as a result.
Why does 'dirty' wiring create surges? Why does 'dirty' wiring create other anomalies? Why do you assume a line conditioner will solve 'dirty' wiring?
If incandescent bulbs do not noticeably change intensity, then wiring (even 1930 vintage) is good. Which specific anomaly concerns you?
After talking to the current tenants, it sounds like they have issues with the power in the apt here and there, which is why I want a line conditioner and a surge protector.
I'll take a look at the Panamax and Furman models and post some ideas here. Much appreciated on the brand names.
So there is one magic box that addresses all anomalies? Of course not. Which ones cause them problems? Open neutral? Brownout? EMI/EMC? Floating ground? Noise? Reverse polarity? RFI? Blackouts? GFCI tripping? High voltage? A list of anomalies is long. Nothing solves all. And nothing adjacent to an appliance averts surges that can actually overwhelm protection that already exists inside appliances.
Again, if a Panamax or Furman did something useful, then those recommendations came with spec numbers. And stated which anomalies are addressed. Neither avert all or even most anomalies. What anomaly must be averted?
Although you are correct and I completely agree with you, it is not possible for me to gain those granular level statistics. And as you say, the list of possible issues can be quite large. So... what I am going to do is go with the all round Panamax MR4300 for a great price thanks to a great AKer.
Sorry for the double post. Had an additional question...
I see that there are two dedicated banks. One for Linear Filtration, the other for High Current. Based on the gear that I will be running, which I posted in the first post, which banks would you recommend I use for which gear?
Thanks
Old thread I know ...
Was looking at the Furman PST8 for entry level protection, but they also have a PST8D. Looks like the main difference on the 8D is it geared more for video equipment with a couple isolated sockets and additional cable connections. Not an issue here, as mine is strictly an audio only system.
Well ... it DOES have an LED monitor for the HTPC, but I don't use it for watching videos. Not sure if there might be a noise issue from the monitor that would be addressed with the 8D?
Recommendation? Amazon has both for the same price.
Under the radar but I've been very happy with my ZeroSurge 8R15W-I (#002-00713) - $229.00. Eight outlets and very high quality.
I wasn't too crazy about the Panamax (@$200) I had. Seemed to restrain the dynamics.
Looks nice, but a bit large for my rack - also more than my cheap self can consider.
Next!
Which anomaly must you protect from? Frequency variation, sag, polarity reversal, harmonics, EMI/EMC, floating neutral, power factor, etc? Why does a Furman not list protection from any of those and others? Because Furman is marketing a magic box to naive consumers. A recommendation without numbers is a first indication of a scam. Where are the Furman numbers that list protection from each type of anomaly?
View spec numbers. For example, it claims transverse mode protection. But problematic electric anomalies that can damage equipment is longitudinal. Why do they not discuss this other and potentially harmful anomaly? Why is so much of that protection already solved inside all electronics?
Again, before anyone can make a useful recommendation, first the relevant anomaly must be defined. If concerned for most common and destructive anomalies, then none of those plug-in 'magic boxes' are a solution.
I would venture to say that your list is a huge leap above the normal issue.
Freq. drifting, floating neutral, power factor, polarity, these are all big $$$ issues to solve with a "box."
Many of them are solved by circuits already inside all electronics. Unfortunately, some consumers want to spend big bucks solving anomalies already made irrelevant by what exists inside each electronic appliance. "Power conditioning" is mostly promoted subjectively (ie by hearsay) - without spec numbers and without knowledge of what electronics already make irrelevant.
Transverse mode protection claimed by a Furman spec sheet is already made irrelevant by what is inside electronics. Why do they not discuss longitudinal mode anomalies? Because those must be solved elsewhere by, for example, a solution that costs about $1 per protected appliance. Using products from other companies with better integrity. Again, which anomaly is a concern? One that can actually do damage? Or one that is already solved?
.....I beg to differ.....
http://www.richardgrayspowercompany.com/pdf/parallel/1200.pdf
http://store.acousticsounds.com/d/13068/Richard_Grays_Power_Company-RGPC_1200-Line_Conditioners
.....the RGPC 1200 Custom....55 pounds, and the metal cabinet might weigh 2 pounds....large
coils (chokes) inside....no heat is produced at all....noise floor is reduced by 50% with 1440
watts (12 amps) of power-on-demand output....the musicality they add, full-range, is VERY
noticeable, especially when you chain two or three....balanced surge protection....if I was
forced to sell my entire system, my three RGPC 12OO's would go last....I bought them used
at an average of about $1200 each.....
.....like I said, they produce no heat, so if you plug it into a wall outlet and hear output with the
components plugged into the back, new or used, you're good to go....I noticed a marked
difference of improvement a few months ago when I got the McIntosh C41 pre, and, noticed
a positive difference with the hanging of the rugs on the side walls to dampen the first reflections,
but without a doubt, these power conditioners were the biggest improvement "ever" to my
sound system....the music literally came to life with much more musicality....I bought my three,
used, at Audiogon.com.....
