Andreas_SWE
Member
I have two 15" woofers (mid-woofers) one Renkus and one EV.
The Renkus is SSL 15-1 and it seems like the EVM 15L is the same. Now I have a EV DL15X lying around as well.
The basket is the same, the depth in magnet for voice coil same, it's not much difference between the size of magnet, size of spider is the same ... I can pluck around the the voice coils and they fit as well as the cone from Renkus fit in EV. The difference is the height of winding and the height of voice coil and that the EV DL15X has a pole piece that is a tad bit higher over the magnet.
So would I be able to use the recone kit for either EVM 15L or DL15X in both?
I had the EVM 15L and would like to have something simliar again. I will see what I choose - it depends on price for recone kits. The EVM 15L should give me a higher upper range which I'm searching for more than a good low end. In that case I think the voice coil lean more towards the measurents of the Renkus.
