Lost Monkey
It's raining - I should wash some vinyl then leave em outside for awhile for a auto rinse cycle, bring em back in later.
Pollutants and acid in the rainwater would probably dissolve the vinyl...
Went and got myself a pair of dent pullers. I played with them a little bit and am having a hard time getting them to stick well: Any thoughts?? I know I have the handles correct, etc.
...Home Depot round outlet covers, bent and domed a for better contact around outside edge of the label; 1/8" neoprene rubber; a threaded knob and knob with stud from McMaster Carr; rubber adhesive.
Uncle Bambi: Were you talking about that SL-D1 above or did you see my recent thread on my 'new' D3?? Real happy with my D3: Its cool....
I think I'm gonna switch to the electrical cover idea and take back the dent pullers; I would just hate to lose suction and drop a record.....especially some of my 70s vintage I'm going to clean!
BTW - nice choice in turn-tables..... I still have the SL-D1 I bought new in 1979 or so. I just recently "upgraded" to a SL-D3 that I found at a garage sale for $5.![]()
Now that's what I need.
But I'd wash and rinse with city water and then final rinse in distilled water, at least for my best or favorite LPs.
Guess I will be buying that LP holder gizmo. Looks good. Makes sense.
Thanks!
There is a small molded dimple in the center of the dent puller making it easy to center the album on the first, then set the second on center. press and lever the pullers together with the album in between.
Here's what I found - I have the older yellow color dent pullers (HF) and the rubber is smoother than the newer red ones which are somewhat rough.
The yellow ones are a breeze, but the red ones I find is a hit and miss trying to get them to work. They went cheaper I guess on the rubber for the newer reds.
The rubber compound feels softer on the yellow ones, so maybe that also contributes in a better/easier seal.
Squeeze them together when you lock them as Jibbajaba and 70WR suggested.
Some of the nast dirty LPs at the thirft/SA/Goodwill have crud, mold, and dirt all over the LP, including the label. Dirt on the label can prevent the dent pullers from sticking properly.Went and got myself a pair of dent pullers. I played with them a little bit and am having a hard time getting them to stick well: Any thoughts?? I know I have the handles correct, etc.
Very, very similar to what I do with mine.
