WaynerN
Addicted Member
I started down this path again after my DIY attempt. My original DIY was a hockey puck with a .284 diameter hole machined in its exact center performed by a friend at his machine shop, using his lathe and a drill bit. The hole and the body are symmetrical. In the end, I thought the puck sucked out detail so I stopped using it.
A few weeks ago, the buy bug bit again and I purchased the Nobsound "Viborg" record weight. It's machined from an aluminum billet, black (or other color) anodized, includes a bubble level, and has a very thin open cell gasket on the bottom for gripping the record label. When I had my VPI in rotation, I used this record weight with it and thought that there was a marked improvement in detail, so the weight, at least for the VPI gets a thumbs up.
Then I put my old Empire 598 into rotation and immediately discovered that the weight was not going to work for a suspended table, so I ordered a record clamp, the Record Doctor with a clear base. When it arrived, it still tipped the suspension slightly, but thought it was OK anyway. Last night listening to some SAGA, I thought the 46 year old table was dishing out some tremendous detail (the very fine stuff) and that lasted for 3 albums of SAGA.
I was curious as to the weight of the weight and the clamp, weight was 275 grams, the clamp came in at 172 grams and the hockey puck weighs 173 grams.
I haven't really tried the Viborg or Record Doctor on my direct drive tables yet, perhaps this afternoon is it is colder then a witches t_t outside and an afternoon of some brews and music is sounding pretty good right now.
BTW, the bubble level on the Viborg is slightly off, at least according to my Audio Technica bubble level.
'ner
'ner
