Your demag looks good from the pix. A demagnitizer is a demagnitizer. If you plug it in and it will pick up a ferrous object, like a nail , then it will demganitize your tape heads.
Something ripped from the Internet
Efective demagnetizing applies the strongest possible magnetic field to all metal tape path parts. This requires
that the demagnetizer’s tip makes close contact with the parts, because a magnetic field’s strength lowers with
the square of the distance. So, choose a demagnetizer that creates a strong magnetic field, the stronger the better.
Avoid cheap demagnetizers because they are barely strong enough to demagnetize a cassette machine head, and
will not demagnetize a capstan or a metal tape guide. The Han-D-Mag, made by R. B. Annis Co., is the strongest
unit made. Contact: R. B. Annis Company, Inc.; 1101 N. Delaware Street, Indianapolis, IN 46202. Or contact
them by telephone at (317)-637-9282.
When you buy your new demagnetizer, cover its tip with heat shrink tubing or plastic electrical tape so it will not
scratch the delicate tape heads.
1.) Turn the power off on the tape recorder or duplicator. Demagnetizing with the power on can damage the
recorder’s circuitry.
2.) Turn the demagnetizer on 3-feet (one meter) or farther from tape or tape machines.
3.) Move the demagnetizer in, very slowly, so its tip touches the head(s), guides, and the capstan.
4.) Move across the surface of each part, and from one part to the next, very slowly and smoothly. If you
accidentally move quickly, go back over that part.
5.) After you have gone over the surface of every metal part in the tape path, very slowly and smoothly
move the demagnetizer away from the recorder until you are at least 3-feet (one meter) away.
6.) Turn off the demagnetizer.
You do not need to hold the demagnetizer in position for a long time; a second or two is sufficient. The only way
you can cause damage while demagnetizing would be to leave the recorder’s power turned on, or to shut off the
demagnetizer while it is close to the recorder or to tapes, or to move the demagnetizer quickly or jerkily. Some
technicians are concerned that the flux from the demagnetizer may damage transistors by strong currents induced
by the play head, even with the power off. This has never happened to my knowledge, but this emphasizes the
need to move the demagnetizer toward and away from the recorder slowly.
Fred
