The Roland R-05 (my former favourite, the Sony PCM-M10, unfortunately isn't available anymore...) currently is ca. 165 Euro, can record in LPCM up to 24 bit/96 kHz as well as in MP3, is portable, sport's built-in microphones, can be run on a pair of AA batteries/rechargeables (and that for quite a few hours) and also features a couple of additional digital tricks like for example playback speed adjustment - so one get's a pretty versatile recorder for a pretty attractive price. And of course, due to the larger storage capacity of the cards (iirc, the R-05 supports cards with 32 GByte max.), one can also record for hours and hours, if need be.
I use the TASCAM CD-RW900MkII. I got it for the same purpose as the OP. It uses CD-R or CD-RW's which are readily available. Also if you have an old computer keyboard with the round style plug, it can be used to add track info directly. It can be done without a keyboard, but it is a PITA using the controls, takes way too much time and effort to scroll through the whole alphabet for every letter you need to input. I've had mine for a while and have burned dozens of CD's with no problem. Just my 2c. Good luck on your search.
I love it when I use it. It's pretty much like recording with tape, setting the record level and button layout. I keep it simple and record each side whole, by not stopping or editing the side will look like one track in a computer. So I title it and say side 1 or 2, In playback it sounds just like listening to the record with maybe some surface noise and time in between tracks. I record at 24bit WAV, then the fact your recording the true vinyl mastering, it sounds awesome as a digital copy. Most CDs you buy are mastered and EQed differently and 16bit or less.I have found several Marantz PMD580 at great prices, seems like this may be a winner... how do you like yours 4-2-7?
Yes far better and...Two questions, please. First, am I correct in understanding that the 24 bit/96 kHz is better resolution than Redbook/CD 16/44.1.
YesIn other words, I'll be getting a file with better quality than CD (whether I can hear it or not is another thing, and another thread).
I think a 4 GB card @ 24bit WAV 96, is around 3 hours. But it really doesn't matter all that much because you can pull the card and transfer the music to your computer, then delete it off the card and start all over again. Well a big card can record a whole day if you need to also.Second, could you give me an idea of how many minutes of recording will fit on 32 GByte card? Such a card goes for about $20, about how many 33 1/3 records would fit (say 45 minutes each)?
Third question (sorry, you've opened a can of worms): could I, a digital dummy, get the files from the Roland onto my iPhone?
Hence a 32 Gbyte card should be good for ca. 20 complete LPs in 24/96 or ca. 65 LPs in 16/44.1.
Greetings from Munich!
Do you also speak Brum in B'ham Alabama?
I am grateful for your response and explanation. But you are a bad, bad man. For the last month I was done buying new audio gear.LOL.
Thanks for your help and 4-2-7. I must have a digital recorder.
Let's not forget to mention that in case you have a laptop to bring to your hi-fi it would be the most cost efficient solution. You'll only need a decent external sound card (interface) which is even cheaper than any recorder.I do not want to attempt to connect to a computer, my desktop is in another room.
Pretty much inline with most line level and preamp outputs for RCA.mains-powered model with an output level of 2 V (on the unbalanced RCA outs)
How do you even motivate yourself to leave the house!!!!!!!!Your welcome.
I bought my PMD580 about 5 years ago and it was one of my second things to add to what will be a very compact and simple system.
But things just kept being added and here we are today and the PMD 580 hasn't moved.
