Rectifier for this RCA EL84 amp console pull?
BmWr75
Top octave? pfffffftttttt
Will soon be coming into possession of what I'm told is an RCA console pull. The only identifying number I can see in the photo is 62122. Anyone seen this model before? Any idea what rectifier tube it might run?
I had an RCA SE similar to this that used a 5Y3 but not sure it's the same one. What's the chassis number to the right of 62122: RS1xxE?
I have one and the rectifier in mine is a 5Y3GT. Sweet little SE amp. If I recall correctly the chassis is a RS-190 something.
I don't have it in my hands yet. So can't provide any more chassis info at this time.
From the transformer layout, possibly RS193
Schematic and parts list here (post #5, see .pdf attachment)
Have the amp now. 62122: RS193F or RS183F or RS133F. Hard to tell what the 4th value is, it is smeared.
Other number below the RS # is RVA274.
Tested the PT today and it was good. Put the rectifier in and got good B+. Cleaned the pots and selector switch. Put some good tubes in it. Powered on with DBT. All OK. Powered it up directly next. One channel quieter than the other by a significant margin. Am sure some caps and maybe resistors need to be changed out. Will do more troubleshooting this week. Superbowl time now, the baby back ribs are smoking!!
Changed out both coupling caps today and one electrolytic. Channel imbalance issue is still a problem. Suspect there is some issue in the balance, bass, treble or volume pots. Have cleaned them with Faderlube. No improvement though. Have swapped the power tubes from right to left. It is not a power tube issue, the quieter speaker doesn't follow the power tube movement. My tube tester doesn't test 6EU7 driver tubes. So can't eliminate that as an issue.
Any troubleshooting suggestions are welcome.
