For my SCHIIT DAC and iPad It was required to use the Lightning USB CAMERA ADAPTER and a powered USB HUB.
A standard USB to Lightning will not deliver the music, it must be the camera adapter cable.
System USB does not supply enough power so the external powered hub is needed.
In my case USB cables- USB A to mini B and a USB A to USB B are used as well to connect the camera adapter to the powered hub
and the powered hub to the DAC.
I do not use the set up on my iMac desktop, instead running it through my hi low mid wi fi system.
Here is a pic, maybe it will be helpful.
