ITChristian
Hello!
I have a Jupiter 203 Reel to Reel Stereo, bought by my grandfather as new. I want to get it working like a new.
It was working almost very well, but it had some problems like a channel being quieter, not being able to record, slow forwarding, but after all a very nice and clear sound.
Note: All my tests were made using the integrated speakers / integrated amp + external speakers / external amp.
At first, I though it should be repaired by an electronicist (as I'm not one) so I found one but after his intervention it sounds worse. Really. He replaced the electrolyte capacitors, the head with a new, the belts...
I started to search for another electronicist, found one, but surprise... Even if he said it is now like a factory one, it is in the worst version ever. The sound is really unclear, with no treble, nor bass (even if only started in amp mode it sounds bad, unclear). It is also recording very but very bad, and it is really quiet. From time to time a vu-meter rises to the highest level and a loud "brr" sound appears. This electronicist also replaced the electrolyte capacitors, the belts, a vu-meter, again.
If you go to my profile you'll see that I am motivated to learn electronics. So I started with an online course (electronicstheory.com) which I just finished. I know I have much more to learn but it is a start point for me. Also I have started watching multiple videos on how to repair a reel to reel.
What I did:
- I tried to set the universal amplifier's variable resistors to default values on the electronic diagram. After that I was surprised to see that it plays no more quieter, and has a nornal volume.
- The sound was still unclear, but it started to sound well in amp mode, so I concluded this is now related to the head.
- I started to align the head by using a good music tape, then a "test tape" recorded by me on another good reel to reel playee, and I did the final calibration using a stroboscope. It really sounds fine now.
However, I still have following problems:
- recording is bad (one channel is quieter on recording, another channel is unclear
- one channel starts to play a "brrrrr" sound randomly so I have to set the volume to 0, then rise it slowly (I switched the universal amplifier modules and the problem moved to the other channel, so the universal amplifier produces this problem)
Can anyone tell me please what to try next? What could be generating the "brrrrr" sound and what should I do?
Also, I have attached the schematic (the plate on the top-left corner is the universal amplifier). Can anoyne explain me what is the use of the variable resistors which I spotted in the picture and how should I set them?
Thank you very much for helping me!
High quality schematics: https://ibb.co/SvngdWf
What I did:
