Refreshing an AU-20000... Help with transistor subs please
JoshHendi
^ElectroNerd^
Hey guys, I am working on recapping/refreshing an AU-20000... I have been inside of a AU20K once before, several years ago for a basic recap. This time around I want to be a little more thorough.
I am not well versed at selecting proper transistor replacements, especially smaller ones. I have a few resources bookmarked for finding transistor subs but I know its not cut and dry and can depend on the circut/application. Im hoping using this thread for a QnA can at least be a good resource for future restorations on this amp.
This unit was properly working before I started so I wouldn't say there were any immediate problem areas, so I more looking to replace any 'known issue' transistors or ones that would improve long-term stability or sound quality.
I am also aware of the many other one-off issues to look for and address in this specific amp, those are well documented elsewhere. Want to focus on transistors here (and while there are a lot of threads regarding this amp, not so many with detailed transistor subs).
Here are the boards, and transistors. Any input would be greatly appreciated and sure others will find this valuable in the future (hopefully)
Edit: Adding bold text to any considered problematic or noisy
F-2511 Protection board
2SC1364 > KSC945C
F-2501 EQ Board F-2505 Flat Amp Board
2SC1313 > KSC1845
2SA726 > KSA992F
2SA917 > 2N5400
2SC1313 > KSC1845
2SA726 > KSA992F
2SC1951 > ZTX694B
F-2495 Tone Amp Board
2SC1708 > KSC1845
2SA726 > KSA992F
F-2496 Meter Board
2SC1313 > 2SC2240 or KSC1845 or BC337
2SC945 > KSC2383 or KSC945
F-2498 Filter Amp Board
2SA726 > KSA992F or KSA992E or BC327
2SC1708 > KSC1845
F-2507 Driver Board (listing transistors from the different versions)
2SC1400 > KSC1845
2SA847 > KSA992
2SC945 > KSC945 or KSC2383
2SA733 > KSA992
F-2508 Regulator Board
2SC1313 > KSC1845
2SA726 > KSA992
2SA847 --- KSA992
2SC1708 > KSC1845
F-2497 Emitter Resistor Board (aka Pass through board)
2SC1364 > 2SC1815 or KSC945C or KSC2383
Output Transistors (Sankens)
2SA909 > MJ21193G
2SC1586 > MJ21194G
For now, I am not including the Driver Boards and the Regulator board. Will circle back to those once I get these harder to access boards covered first.
And please I am not expecting someone to spend a lot of time and research on finding replacements, just hoping the collective can throw out a few here and there and I will update the OP with recommendations.
Am I being to paranoid about selecting the wrong replacement 'for the specific application' when it comes to these small signal transistors?
@Hyperion thank you for that link, Ive updated the original post with what I could get from there
Attached is my master sub list. You can never replace too many transistors IMO.
Thank you!
Also through a series of links from Hyperions reply, I came across this: https://audiokarma.org/forums/index.php?threads/once-more-sansui-transistor-substitutions.583009/
Ill get my OP updated, but between these four resources I think we got it covered.
And just a friendly reminder if you are here for reference, it can never hurt to double check, and always verify your ECB layout!
List is complete, if anyone has objections or spots a non-suitable replacement for the specific application please let us know (excluding pin layout)
2SA818 is KSA1381. 2SA847 is KSA992. 2SC1708 is KSC1845 - if you're replacing it's complement with KSA992, don't mix and match.
I see an NTE sub in there too. No good. Not to mention pretty much all subs should be KSA/KSC's.
Listed updated. Does the list look okay now based on your reply?
2SC1364 > KSC945C
2SC1313 > KSC1845
2SA726 > KSA992F
2SA917 > 2N5400
2SC1313 > KSC1845
2SA726 > KSA992F
2SC1951 > ZTX694B
2SC1708 > KSC1845
2SA726 > KSA992F
F-2496 Meter Board
2SC1708 > KSC1845
2SC1400 > KSC1845
2SA847 > KSA992
2SA733 > KSA992
2SC1313 > KSC1845
2SA726 > KSA992
2SA847 --- KSA992
2SC1708 > KSC1845
2SA909 > MJ21193G
2SC1586 > MJ21194G
hello. I´m getting hard to find mj2113/94g.
Can mj15023/024 (without "G") be good replacements for 2sc1586/2sa909???
i´d like to restore my 2385.
regards.
